The total G2 (for a categorical response) or SS, sum of squares (for a continuous response), attributed to the column.
Provides various options for displaying trees in the Tree Views report. The report gives a picture of the tree that is fit at each layer of the boosting process. For a description of the Prob column shown by the Show names categories estimates option, see Predicted Probabilities in Decision Tree and Bootstrap Forest in Partition Models.
Creates a prediction formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See the Formula Depot topic.
(The Publish Prediction Formula option should be used instead of this option. Use this option only when Publish Prediction Formula is not available.) Creates a tolerant prediction formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See the Formula Depot topic. If you have selected Informative Missing, you can use this option by holding the Shift key as you click on the report’s red triangle.
(Available only for categorical responses.) Enables you to specify profit or costs associated with correct or incorrect classification decisions. See Show Fit Details in Partition Models.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
