Select Graph > Graph Builder.
Drag the Latitude column to the Y axis.
Drag the Longitude column to the X axis.
Right-click the graph and select Graph > Background Map.
6.
Figure 14.40 Background Map
Figure 14.41 Unclipped Contours on Background Map
On the Latitude axis, double-click 45°00’ N to open the Y Axis Settings window.
Figure 14.42 Unclipped Reference Line
Right-click the graph and select Customize.
Figure 14.43 Clipped Reference Line and Contours
The boundaries that appear in the Background Map window are installed in the JMP Maps installation folder. See Custom Map Files for details about adding your own boundaries.
