Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Choice Designs
• Choice Design Window
The Choice Design window walks you through the steps to construct a choice design for modeling attribute preferences. You can specify an assumed model and prior information.
The Choice Design window updates as you work through the design steps. The outlines, separated by buttons that update the outlines, follow the flow in
Figure 17.15
Figure 17.15
Choice Design Flow
Help created on 7/12/2018
