Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Cluster Variables
The Cluster Variables Report
• Cluster Members
Cluster Members
The Cluster Members report gives the following:
Cluster
The cluster identifier.
Members
The variables included in the cluster.
RSquare with Own Cluster
The squared correlation of the variable with its cluster component.
RSquare with Next Closest
The squared correlation of the variable with the cluster component for its next closest cluster. The next closest cluster is the cluster for which the squared correlation of the variable with the cluster component is the second highest.
1 - RSquare Ratio
A measure of the relative closeness between the cluster to which a variable belongs and its next closest cluster. It is defined as follows:
(1 - RSquare with Own Cluster)/(1 - RSquare with Next Closest)
Help created on 7/12/2018
