From the red triangle menu for Chart, select Level Options > Colors.
Note: If you assigned both a category variable and a grouping variable in your chart, all of the bars are colored even if you selected only one bar.
Right-click and select Colors.
Select Cols > Column Info.
Assign colors using Value Colors in the Column Properties menu. For details about the Value Colors property, see Value Colors in the Using JMP book.
