Tip: If you find that the report window is too long, select Tabbed Report from the red triangle menu.
The Competing Cause report appears if you have assigned a Failure Cause column in the launch window. Use this report to analyze the competing causes to determine which causes are influential. For an example of this report, see Omit Competing Causes. For technical details, see Competing Cause Details.
