Enter, view, edit, and manipulate data using JMP data tables.
Select a platform from the Analyze, Graph, or DOE menus. Platforms contain interactive windows that you use to analyze data and work with graphs.
Launch windows where you set up and run your analysis.
Report windows showing the output of your analysis.
