Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis
Bivariate Analysis
Statistical Details for the Bivariate Platform
• Correlation Report
Correlation Report
The Pearson correlation coefficient is denoted
r
, and is computed as follows:
where
Where
is either the weight of the
i
th observation if a weight column is specified, or 1 if no weight column is assigned.
Help created on 7/12/2018
