Provides the details of the analysis including the singular values, inertias, ChiSquare statistics, percent, and cumulative percent. This report appears by default. See Show Detail.
Provides reports of the Benzecri and Greenacre adjusted inertia. See Benzécri (1979) and Greenacre (1984). This option is not available when there are one or more X variables. See Show Adjusted Inertia.
Provides a report of up to the first three principal coordinates for the categories in the analysis, as appropriate. See Show Coordinates.
Provides a report of the summary statistics, Quality, Mass, and Inertia, for each category in the analysis. See Show Summary Statistics.
Provides a report of the contribution of each category to the inertia for each of up to the first three dimensions. See Show Partial Contributions to Inertia.
Provides a report of the squared cosines of each category for each of up to the first three dimensions. The report includes a bar chart that shows, for each level of each Y variable, the squared cosine values for each of up to the first three dimensions. See Show Squared Cosines.
(Available only when all of the Y variables have the same set of only two levels and the X variable has a unique value for each row.) Provides Cochran’s Q statistic, which tests that the marginal probability of a specific response is unchanged across the Y variables. Cochran’s Q statistic is a generalization of McNemar’s statistic for more than two response variables. See Agresti (2013).
