Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Prospective Sample Size and Power
Counts per Unit Calculator
• Counts per Unit Calculator Fields
Specify the following quantities:
Alpha
The probability of a type I error, which is the probability of rejecting the null hypothesis when it is true. It is commonly referred to as the significance level of the test. The default alpha level is 0.05.
Baseline Count per Unit
The number of targeted defects per unit. The default value is 0.1.
Specify two of the following quantities to calculate the third quantity:
Difference to detect
The smallest detectable difference to test against specified in defects per unit.
Sample Size
The number of units.
Power
The probability of rejecting the null hypothesis when it is false. With all other parameters fixed, power increases as sample size increases.
Calculator Buttons
Continue
Evaluates the missing value.
Back
Returns to the previous Sample Size and Power launch window.
Help created on 7/12/2018
