Double-click the column name to which you want to apply the formula, select Formula from the Column Properties menu, and then click Edit Formula.
When you type, a small text editor window appears, which enables you to edit the formula. You can click the Maximize editor button
Figure 6.2 Building a Formula
See Use Basic Formula Editor Features, for an example of how to use the Formula Editor.
You can also use the Formula Editor to define a custom format. For example, you might want to convert a number from inches to centimeters using the calculation Char( :height * 2.54 ) || " cm". Realize that the underlying data, which you see when double-clicking a data table cell, would still be the value of :height.
:Y - Col Mean( If( :Status == "nonsmoker", :Y, . ), :Cycle )
In a new Y2 column, create this formula:
:Y,
:Y - Col Mean( :Name( :Y2, :Cycle )
