project = New Project();
project << Add Bookmarks({
              File( "$SAMPLE_DATA/Big Class.jmp" )
Run Script opens the data table and creates output inside the project.
project << Run Script(
	Open(
		"$SAMPLE_DATA/Big Class.jmp",
		Set Window ID( "data" ) // unique window ID
	Distribution(
		Set Window ID( "distrib" ),
		Continuous Distribution( Column( :weight ) ),
		Nominal Distribution( Column( :age ) )
	Graph Builder(
		Set Window ID( "graphbuilder" ),
		Size( 443, 409 ),
		Show Control Panel( 0 ),
		Fit to Window( "Maintain Aspect Ratio" ),
		Variables( X( :age ), Y( :height ), Y( :weight ) ),
		Elements( Position( 1, 1 ), Line( X, Y, Legend( 1 ) ) ),
		Elements( Position( 1, 2 ), Bar( X, Y, Legend( 2 ) ) )
Set Layout specifies the layout of the tabs that show the data table and output.
project << Set Layout(
	H Splitter Box(
		<<Set Sizes( {0.15, 0.85} ),
		V Splitter Box(
			Size( 182, 700 ),
			<<Set Sizes( {0.5, 0.5} ),
			Tab Page Box( // show the Bookmarks pane
				Window ID( "Bookmarks" )
			Tab Page Box( // show the Windows pane
				Window ID( "Windows" )
		V Splitter Box(
			<<Set Sizes( {0.85, 0.15} ),
			H Splitter Box(
				<<Set Sizes( {0.43, 0.57} ),
				Tab Page Box( // show the data table
					Window ID( "data" )
				Tab Box(
					Tab Page Box( // show the Distribution graph and reports
					Tab Page Box( // show the Graph Builder graph
			Tab Page Box(
				Window ID( "Log" ) )
Save saves the project.
project << Save( "$DOCUMENTS/Big Class.jmpprj" );
// If the project has already been saved, the Save message
// with no argument saves the file to the existing location.
Figure 14.2 Example of a Complex Project
project = Open( "Big Class.jmpprj" );
Help created on 7/12/2018
