Figure 3.50 Scripts Saved With the Data Table
Select Help > Sample Data Library and open Big Class.jmp.
Select Analyze > Fit Y by X.
Select weight and click Y, Response.
Select height and click X, Factor.
From the red triangle menu, select Save Script > To Data Table.
11.
Tip: If you want a particular script to run automatically every time the data table is opened, name the script OnOpen. Only one script saved in the data table can be set to run automatically. If you name the script Model (or model) in a Fit Model script, the launch window is automatically filled in based on the script when you select Analyze > Fit Model.
Figure 3.51 Creating a Script
Select New Script.
If you are finished editing the script, click OK. The script appears in the Table panel and the window closes.
If you are not finished editing the script and want to save it, click Save. The script appears in the Table panel and the window remains open for further editing.
Help created on 7/12/2018
