Select DOE > Classical > Mixture Design.
Click the Mixture Design red triangle and select Load Factors.
Click Continue.
Enter 3 in the Degree box.
6.
Click Extreme Vertices.
7.
Figure 12.21 Extreme Vertices Mixture Design
8.
9.
Figure 12.22 Ternary Plot for Design
Figure 12.23 Identify Vertices and Center Point
11.
Select Edit > Copy, to copy the selected rows to the clipboard.
12.
Click in the first cell of row 10 and select Edit > Paste to add the duplicate rows to the table.
The Plasticizer design with the results (Y values) that Cornell obtained are available in the sample data file Plasticizer.jmp.
