Select DOE > Special Purpose > Space Filling Design.
Alter the factor level values, if necessary. Figure 20.10 shows adding two factors to the two existing factors and changing their values to 1 and 8 instead of the default –1 and 1.
Figure 20.10 Space-Filling Dialog for Four Factors
Click Continue.
In the design specification dialog, specify a sample size (Number of Runs). This example uses a sample size of eight.
6.
Click Latin Hypercube (see Figure 20.7). Factor settings and design diagnostics results appear similar to those in Figure 20.11, which shows the Latin Hypercube design with four factors and eight runs.
Figure 20.11 Latin Hypercube Design for Four Factors and Eight Runs with Eight Levels
Help created on 7/12/2018
