Contains options identical to the Factor Settings submenu in the Prediction Profiler. See Factor Settings in Profiler.
Creates a data table that contains iterations of the optimization algorithm. The data table appears after the Optimize button is clicked.
Enables you to add, change, or delete linear constraints. The constraints are used in the Custom Profiler. See Linear Constraints in Introduction to Profilers.
