The factors and their settings are given in the data table Extraction Factors.jmp. You create a definitive screening design to investigate.
Select DOE > Definitive Screening > Definitive Screening Design.
From the red triangle menu, select Load Factors.
Figure 6.2 Responses and Factors for Extraction Design
Click Continue.
The Design Options outline opens. Here you can specify a blocking structure. There is no need to block in this example, so you accept the default selection of No Blocks Required.
6.
Click Make Design.
Figure 6.3 Design Outline
7.
Open the Design Evaluation > Color Map on Correlations outline.
8.
