Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Space-Filling Designs
Space Filling Design Window
• Design
Design
The Design outline shows the runs for the space-filling design.
Design Diagnostics
The Design Diagnostics outline shows the values for the factors scaled from zero to one. The Minimum Distance is based on these scaled values and is the minimum distance from each point to its nearest neighbor. The row number for the nearest neighbor is given in the Nearest Point column. The discrepancy value shown below the table is the integrated difference between the design points based and a uniform distribution.
Design Table
Make Table
Constructs the Space Filling Design data table.
Back
Takes you back to where you were before clicking
Make Design
. You can make changes to the previous outlines and regenerate the design.
Help created on 7/12/2018
