Provides several options connected with the scoring of the observations. In particular, you can save the scoring formulas. See Score Options.
Shows a three-dimensional canonical plot. This option is available only when there are four or more levels of the categorical X. See Example of a Canonical 3D Plot.
Used when you have some points that might not fit any known group, but instead might be from an unscored new group. For details, see Consider New Levels.
Shows or hides a Group Means report that provides the means of each covariate. Means for each level of the X variable and overall means appear.
Saves a script called Discrim Results to the data table. The script is a list of the following objects for use in JSL:
Save Discrim Matrices is not available for the Wide Linear discriminant method. See Save Discrim Matrices.
Opens a separate window containing a Scatterplot Matrix report that shows a matrix with a scatterplot for each pair of covariates. The option invokes the Scatterplot Matrix platform with shaded density ellipses for each group. The scatterplots include all observations in the data table, even if validation is used. See Scatterplot Matrix.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
