Draws a horizontal line through the mean of each group proportional to its x-axis. The top and bottom points of the mean diamond show the upper and lower 95% confidence points for each group. See Mean Diamonds and X-Axis Proportional.
Identifies the mean of each group and shows error bars one standard error above and below the mean. See Mean Lines, Error Bars, and Standard Deviation Lines.
Draws the overall mean of the Y variable on the plot.
Shows lines one standard deviation above and below the mean of each group. See Mean Lines, Error Bars, and Standard Deviation Lines.
Shows or hides comparison circles. This option is available only when one of the Compare Means options is selected. See Comparison Circles. For an example, see Conduct the Oneway Analysis.
Makes the spacing on the x-axis proportional to the sample size of each level. See Mean Diamonds and X-Axis Proportional.
Adds small spaces between points that overlay on the same y value. The horizontal adjustment of points varies from 0.375 to 0.625 with a 4*(Uniform-0.5)5 distribution.
(Only appears when the Matching Column option is selected.) Connects matching points.
(Only appears when the Matching Column option is selected.) Draws dotted lines to connect cell means from missing cells in the table. The values used as the endpoints of the lines are obtained using a two-way ANOVA model.
