Select Help > Sample Data Library and open Companies.jmp.
Select the Type column by clicking once on the column heading.
Select Cols > Recode.
Click Done and select the In Place option from the list.
Figure 1.17 Recode Window
Select Fill > Repeat sequence to end of table.
To continue a pattern instead of repeating it (1, 2, 3, 4, 5, 6, ...), select Continue sequence to end of table. This command can also be used to generate patterns like (1, 1, 1, 2, 2, 2, 3, 3, 3, ...).
Help created on 7/12/2018
