Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Scripting Guide
Scripting Platforms
Specify Which Columns to Analyze
• Enable Users to Specify Columns
Instead of specifying analysis columns yourself, you can enable a user to specify them, but you can still control what happens after they do so. In this case, use an empty specification. The following example runs the Distribution launch window:
Distribution();
In this scenario, the Distribution launch window appears and the user can choose the columns to analyze. After the user selects the columns and clicks
OK
, the Distribution report is shown as specified.
Help created on 7/12/2018
