The following example illustrates constructing a control chart for data that are not sub-grouped. The data are measurements on a steam turbine engine. For an example that uses sub-grouped data, Example of Monitoring a Process Using Sub-Grouped Data.
Select Analyze > Quality and Process > Control Chart > Multivariate Control Chart.
Select all of the columns and click Y, Columns.
Click OK.
Figure 6.2 Initial Multivariate Control Chart
