This example uses the Pogo Jumps.jmp sample data table. The data, adapted from Aitchison (1986), show measurements for pogo jumps of seven finalists in the 1985 Hong Kong Pogo-Jump Championship. A single pogo jump is the total jump distance in three consecutive bounces, referred to as yat, yee, and sam.
Click OK.
Figure 12.2 Example of a Ternary Plot
Figure 12.3 Using the Crosshairs Tool
Right-click on the plot and select Row Legend.
Select Finalist in the column list box.
Colors should be automatically set to JMP Default.
Click OK.
Figure 12.4 Pogo Data Colored by Finalist
