This example is in three parts. In most cases, you would start with Create the Baseline Control Chart, where you let JMP calculate the control limits for you. Then, to apply these control limits to new data, you would either Specify Control Limits or Specify Multiple Sets of Control Limits (for phase data).
Select Analyze > Quality and Process > Control Chart Builder.
Figure 2.8 XBar and R Chart of Line Length by Print Run
If we had determined that our process was not in control, we would do further research to figure out how we could alter our process so that it is in control. For this example, since the process is already in control or stable, we can skip that step. Now, you can use these control limits with new data. Proceed to Specify Control Limits, or Specify Multiple Sets of Control Limits (to see an example with phase data).
Click OK.
8.
10.
Click OK.
Click OK.
7.
8.
9.
To use the Get Limits method, you need a data table that defines your historical limits. For detailed information about how to create a limits table, see Saving and Retrieving Limits in Shewhart Control Charts.
Click the Control Chart Builder red triangle and select Get Limits. Navigate and open the limits data table for this example, called Length Limits.jmp. By default, the file is located here:
On Windows: C:\Program Files\SAS\JMP\<version>\Samples\Data
On Macintosh: \Library\Application Support\JMP\<version>\Samples\Data
Figure 2.11 Baseline Control Chart for Existing Data
From the report in Figure 2.11, click the red triangle next to Control Chart Builder and select Save Limits > in New Table.
7.
8.
Click the red triangle next to Control Chart Builder and select Get Limits. Open the limits table you saved in step 2.
