This example uses the Crime.jmp sample data table, which contains data on crime rates for each US state.
Select Graph > Graph Builder.
Figure 14.2 Example of Burglary by State
The legend shows the colors that correspond to the burglary rates. Since Burglary is a continuous variable, the colors are based on a continuous color theme. Figure 14.2 uses the JMP default continuous theme. You can change the theme under File > Preferences > Graphs.
