Select Help > Sample Data Library and open Big Class.jmp.
Run the Distribution table script to generate the report.
Select File > New > Application (or File > New > New Application on Macintosh).
Figure 15.2 New Application with Distribution Report in the Sources Pane
The Distribution report appears in a new window (Figure 15.3). Note that the histograms are interactive and still associated with the data table. When the data changes, you run the application again, and the Distribution report is updated.
Figure 15.3 Example of an Instant Application
Help created on 7/12/2018
