The Liver Cancer.jmp sample data table contains data on the severity of liver cancer in patients when they entered a study. The file also contains a number of table scripts for models. This example uses these scripts to generate models to demonstrate the Formula Depot.
Click the red triangle next to Adaptive Lasso with Validation Column and select Save Columns > Publish Prediction Formula.
To add the prediction formula to the data table, select Run Script from the Fit Generalized - Node Count red triangle menu in the Formula Depot.
Note: The result of step 3 and step 4 can be obtained using the Save Columns > Save Prediction Formula at step 3. However, then the prediction formula is not part of the Formula Depot
To save the Formula Depot, select File > Save.
Figure 10.2 Formula Depot with a Generalized Model
