Notice Lung Cancer Responses.jmp has only one column (Lung Cancer) with two rows (Cancer and NoCancer).
Select Multiple Tables, Cross-Referenced from the list next to Data Format.
Figure 5.37 Completed Profile Data Panel
8.
Open the Response Data outline.
9.
Figure 5.38 Completed Response Data Panel
11.
Open the Subject Data outline.
12.
13.
Figure 5.39 Completed Subject Data Panel
14.
Click Run Model.
Figure 5.40 Choice Modeling Logistic Regression Results
Because the data table contains a model script, the Model Specification window is automatically completed. The Nominal Logistic personality is selected.
Click Run.
Figure 5.41 Fit Model Nominal Logistic Regression Results
Notice that the likelihood ratio chi-square test for Smoker*Lung Cancer in the Choice model matches the likelihood ratio chi-square test for Smoker in the Logistic model. The reports shown in Figure 5.40 and Figure 5.41 support the conclusion that smoking has a strong effect on developing lung cancer. See Logistic Regression Models in the Fitting Linear Models book for more details.
