For static bubble plots, you might specify one or two ID variables and no Time variable. The resulting bubble plot contains a bubble at each ID value. Note that although this bubble plot is static, you can perform splitting on bubbles.
Select Help > Sample Data Library and open PopAgeGroup.jmp.
Select Graph > Bubble Plot.
Select Portion60+ and click Y.
Select Portion 0-19 and click X.
Select Region and Country and click ID.
6.
Select Region and click Coloring.
7.
Figure 7.9 Initial Report Window with ID Variables
9.
Click Split.
Figure 7.10 Splitting the North America Bubble
Help created on 7/12/2018
