The data in the Weight Measurements.jmp sample data table shows the height and weight measurements taken by 40 students.
Select Analyze > Fit Y by X.
Click OK.
6.
From the red triangle menu, select Fit Line.
7.
From the red triangle menu, select Robust > Fit Robust.
Figure 4.45 Example of Robust Fit
