The data in the Drug Toxicity.jmp sample data table shows the toxicity levels for three different formulations of a drug.
Select Analyze > Fit Y by X.
Click OK.
6.
From the red triangle menu, select Means/Anova.
7.
From the red triangle menu, select Robust > Robust Fit.
Figure 5.80 Example of Robust Fit
