Select Graph > Scatterplot Matrix.
Click OK.
Figure 11.7 Initial Example Using a Grouping Variable
6.
From the red triangle menu, select Density Ellipses > Density Ellipses.
7.
From the red triangle menu, select Density Ellipses > Shaded Ellipses.
Figure 11.8 Example of a Scatterplot Matrix with Ellipses
