Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis
Simulate
• Examples That Use Simulate
This section provides several examples of the use of Simulate. Additional examples, also listed below, can be found in other books:
Construct Nonparametric Confidence Intervals for Variance Components
Conduct a Permutation Test
Explore Retaining a Factor in Generalized Regression
Conduct Prospective Power Analysis for a Nonlinear Model
For an example that shows how to simulate a confidence interval for Ppk and the percent nonconforming for a non-normal variable, see
Simulation of Confidence Limits for a Nonnormal Process Ppk
in the
book.
Help created on 7/12/2018
