Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Scripting Guide
Scripting Tools
Using the Script Editor
• Find and Replace
Find and Replace
Many find and replace options are available in the script editor, including the support of regular expressions. For example, searching with the following regular expression:
get.*name
returns messages such as “Get Button Name”, and “GetFontName”
Basic regular expressions such as
and
(which match the start of line and end of line) and
\n
(which matches a carriage return) are also supported.
See
Find Window Options
in the
Using JMP
book for details about the Search options.
Help created on 7/12/2018
