Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Functional Data Explorer
Functional Data Explorer Platform Options
• Fit Group Options
Fit Group Options
Fit Group options are available only when a By variable is used in the analysis or when there are multiple functional processes specified in the Stacked Data Format tab in the launch window.
Arrange in Rows
Specifies how many reports are displayed across the window.
Order by Goodness of Fit
(Applicable only after fitting a model to each functional process.) Reorders the individual reports by goodness of fit.
See
Local Data Filter
Redo Menus
, and
Save Script Menus
in the
Using JMP
book for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
Help created on 7/12/2018
