Shows all responses in a single profiler. You can view the effects of model terms on all responses simultaneously and perform multiple optimization. See Profiler.
Sorts the reports by significance of fit (RSquare). This option is available only for platforms that surface the RSquare to the platform level. For example, if you have hundreds of Oneway analyses generated from one launch window, they will appear in a FitGroup and you can sort them so that the strongest relationships appear first.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
