Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Scripting Guide
Scripting Platforms
Scripting-Only Messages and Arguments by Platform
• Fit Life by X
Fit Life by X
The following messages for a Fit Life by X object are available only in JSL:
fit_life_object << Set Scriptables( ... );
// set scriptable options within the profilers in different sections of the output
fit_life_object << Get Results
// return the estimates, standard errors, covariance matrix, and convergence results for each distribution fit
Help created on 7/12/2018
