Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis
Bivariate Analysis
Fit Mean
• Fit Mean Report
Fit Mean Report
The Fit Mean report shows summary statistics about the fit of the mean.
Mean
Mean of the response variable. The predicted response when there are no specified effects in the model.
Std Dev [RMSE]
Standard deviation of the response variable. Square root of the mean square error, also called the root mean square error (or RMSE).
Std Error
Standard deviation of the response mean. Calculated by dividing the RMSE by the square root of the number of values.
SSE
Error sum of squares for the simple mean model. Appears as the sum of squares for
Error
in the analysis of variance tables for each model fit.
For details about the options in the Fit Mean menu, see
Fitting Menus
Help created on 7/12/2018
