Enables you to select models from the current formula depot to be copied. Selected models are copied onto the clipboard within a Transform Columns() statement.
Enables you to select models from the current formula depot for code generation. A new script window appears that contains scoring code for the selected models in C, Python, JavaScript, SAS DS2, or SQL, respectively. You can use this code to facilitate the deployment of the model in the environment or framework of your choice. See Generating Scoring Code from the Formula Depot Platform.
Enables you to select models from the current formula depot to be compared using the model comparison utility. If models from multiple tables are stored in the depot you first select the table of interest and then the models of interest. See Model Comparison in the Predictive and Specialized Modeling book.
Enables you to select models from the current formula depot to be profiled using the profiler. If models from multiple tables are stored in the depot you first select the table of interest and then the models of interest. See Profiler in the Profilers book.
See Redo Menus and Save Script Menus in the Using JMP book for more information about the following options:
