Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Essential Graphing
Graph Builder
• Graph Builder Buttons
The Graph Builder window contains these buttons:
Recall
Populates the Graph Builder window with the last graph that you created. This button changes into the Undo button once you perform an action.
Dialog
Opens the Graph Builder launch window. This button changes into the Start Over button once you perform an action. You can add a By variable in the Graph Builder launch window.
Done
Hides the buttons, Columns list, and all drop zone outlines. Equivalent to de-selecting the Show Control Panel option.
Use this presentation-friendly format for pasting into other applications. To copy the graph, select
Edit > Copy
. To restore the window to the interactive mode, click the Graph Builder red triangle and select
Show Control Panel
Undo
Reverses the last change made to the window.
Start Over
Returns the window to the default condition, removing all data and graph elements from the window, and all variables from the drop zones.
Help created on 7/12/2018
