Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Essential Graphing
Graph Builder
Right-Click Menus
• Grouping Zones Options
Right-clicking in the X Group, Y Group, Wrap, and Overlay zones can show the following options:
Levels in View
Changes the number of levels of the grouping variable that are visible. Use the arrow buttons to scroll forward and backward.
Number of Levels
Changes the number of levels. See
Categorical and Continuous Variables in Group X or Y Zones
Order By
Orders the levels of a variable. See
Order the Levels of a Categorical Variable
Show Title
Shows or hides the variable title.
Title Orientation
Changes the orientation of the variable text to horizontal or vertical.
Level Orientation
Changes the orientation of the level values to horizontal or vertical.
Levels per Row
Changes the number of columns included in the graph. Use with a
Wrap
variable.
Color
Changes the background color of the grouping zone.
X or Y Group Edge
Moves the grouping variable labels. See
Move Group X and Group Y Labels
Swap
Swaps the position of two variables. See
Move or Remove Variables in Zones
Remove
Removes a variable.
Help created on 7/12/2018
