Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Process Capability
Launch the Process Capability Platform
• Historical Information
Use this outline to assign historically accepted values of the standard deviation to variables in the Y, Process list.
Select a variable or variables in the Y, Process list.
Enter a value next to Set Historical Sigma.
Select Use Historical Sigma to assign that value to the selected variables.
The specified value appears in parentheses in the expression “&Sigma()” to the right of the variable names in the Y, Process list.
Note:
If you set a historical sigma, then subgroup assignments for the selected process variable are no longer relevant and are removed.
Help created on 7/12/2018
