When you click OK in the launch window, the Iterative Clustering report window appears, showing a Control Panel for fitting models. See Iterative Clustering Control Panel. As you fit models, additional reports are added to the window. See K Means NCluster=<k> Report.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
