Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
K Means Cluster
K Means NCluster=<k> Report
• K Means NCluster=<k> Report
The K Means NCluster=<k> report gives the following summary statistics for each cluster:
The Cluster Summary report gives the number of clusters and the observations in each cluster, as well as the number of iterations required.
The Cluster Means report gives means for the observations in each cluster for each variable.
The Cluster Standard Deviations report gives standard deviations for the observations in each cluster for each variable.
Help created on 7/12/2018
