The number of parameters other than the μ in the hypothesis test. This option can be used for multi-factor designs. Leave the default 0 in this field in simple cases.
The total number of observations (runs, experimental units, or samples) in your experiment. Use a sample size of n/k in each group, where n is the total number of observations.
