Select Analyze > Fit Y by X.
Enter a continuous column for Y, Response.
Enter a continuous column for X, Factor.
Figure 4.26 The Bivariate Launch Window
Note: You can also launch a bivariate analysis from the JMP Starter window. Select View > JMP Starter > Basic > Bivariate.
