You can launch the Fit Model platform by selecting Analyze > Fit Model. Figure 1.3 shows an example of the launch window for the Fitness.jmp sample data table.
Figure 1.3 Fit Model Launch Window
Note: When you select Analyze > Fit Model in a data table that has a script named Model (or model), the launch window is automatically filled in based on the script.
