Select Analyze > Fit Y by X.
Enter a nominal or ordinal column for Y, Response.
Enter a continuous column for X, Factor.
Figure 7.116 Fit Y by X Launch Window
Note: You can also launch a logistic analysis from the JMP Starter window. Select View > JMP Starter > Basic > Logistic.
