Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Consumer Research
Multiple Factor Analysis
• Launch the Multiple Factor Analysis Platform
Launch the Multiple Factor Analysis Platform by selecting
Analyze > Consumer Research > Multiple Factor Analysis
Figure 8.4
The Multiple Factor Analysis Launch Window
Product ID
Specifies columns of items or products to be analyzed.
Z, Supplementary
Specifies the columns to be used as supplementary variables. These variables are those with which you are interested in identifying associations, but they are not included in the calculations.
Freq
Identifies one column whose numeric values assign a frequency to each row in the analysis.
Add Block
Performs one of the following actions:
Adds individual columns as a single block.
Adds a column group as a block.
Adds individual columns to a selected block.
Tip:
If you group the columns into blocks before running the platform, you can select multiple column groups and cast them as blocks in a single action. Otherwise, you must select each group of columns for each block and click Add Block, one block at a time. Double-click on a block name to change it.
Help created on 7/12/2018
